Ir para o conteúdo principal
Disassembling Nokia E61i Keyboard
O que você precisa
  1. Disassembling Nokia E61i Keyboard, Battery: passo 1, imagem 1 %32 Disassembling Nokia E61i Keyboard, Battery: passo 1, imagem 2 %32
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Keyboard: passo 2, imagem 1 %32
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Keyboard: passo 3, imagem 1 %32
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Keyboard, Front Cover: passo 4, imagem 1 %32 Disassembling Nokia E61i Keyboard, Front Cover: passo 4, imagem 2 %32
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Keyboard: passo 5, imagem 1 %32
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Keyboard, Keyboard: passo 6, imagem 1 %32
    • Once the front cover has been removed, there is nothing holding the keyboard to the rest of the phone. Simply remove the keyboard from the cover by lifting the keyboard from its interior side.
Conclusão
Equipe
Cal Poly, Team 9-63, Walters Spring 2011 Membro de Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,694
