Ir para o conteúdo principal
Nokia E61i Connector Housing Replacement
O que você precisa
  1. Nokia E61i Connector Housing Replacement, Battery: passo 1, imagem 1 %32 Nokia E61i Connector Housing Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Connector Housing Replacement: passo 2, imagem 1 %32
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Connector Housing Replacement: passo 3, imagem 1 %32
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Connector Housing Replacement, Front Cover: passo 4, imagem 1 %32 Nokia E61i Connector Housing Replacement, Front Cover: passo 4, imagem 2 %32
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Connector Housing Replacement: passo 5, imagem 1 %32
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Connector Housing Replacement, Display: passo 6, imagem 1 %32 Nokia E61i Connector Housing Replacement, Display: passo 6, imagem 2 %32
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Connector Housing Replacement: passo 7, imagem 1 %32 Nokia E61i Connector Housing Replacement: passo 7, imagem 2 %32
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Connector Housing Replacement, Motherboard: passo 8, imagem 1 %32 Nokia E61i Connector Housing Replacement, Motherboard: passo 8, imagem 2 %32 Nokia E61i Connector Housing Replacement, Motherboard: passo 8, imagem 3 %32
    • Pull the green motherboard from the back casing.
  9. Nokia E61i Connector Housing Replacement, Connector Housing: passo 9, imagem 1 %32
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
Conclusão
Equipe
Cal Poly, Team 9-63, Walters Spring 2011 Membro de Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 2,130
