Ir para o conteúdo principal
Disassembling Nokia 6236i Keypad
O que você precisa
  1. Disassembling Nokia 6236i Keypad, Battery: passo 1, imagem 1 %32 Disassembling Nokia 6236i Keypad, Battery: passo 1, imagem 2 %32
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Disassembling Nokia 6236i Keypad: passo 2, imagem 1 %32 Disassembling Nokia 6236i Keypad: passo 2, imagem 2 %32 Disassembling Nokia 6236i Keypad: passo 2, imagem 3 %32
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Disassembling Nokia 6236i Keypad, Front Casing: passo 3, imagem 1 %32 Disassembling Nokia 6236i Keypad, Front Casing: passo 3, imagem 2 %32 Disassembling Nokia 6236i Keypad, Front Casing: passo 3, imagem 3 %32
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
  4. Disassembling Nokia 6236i Keypad, Keypad: passo 4, imagem 1 %32
    • With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • In all probability, it will already have fallen out and no removal is required.
Conclusão
Uma outra pessoa concluiu este guia.
Erik Lindahl
Membro desde: 04/18/10
63 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 10-46, Garner Spring 2010 Membro de Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 978
