Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
The battery should lift out with minimal resistance.
Insert a spudger into the indention on the bottom right side of the device.
Slide the spudger upward to a second indention at the top of the phone.
The front casing will detach from the phone.
Use the flathead screwdriver to remove four screws on the upper half of the phone.
Lift the LCD up and off.
