Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide helps you remove the display from the phone.
O que você precisa
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Insert a spudger into the indention on the bottom right side of the device.
Slide the spudger upward to a second indention at the top of the phone.
The front casing will detach from the phone.
Locate the four screws on the upper half of the phone as indicated in the photo.
Using the screwdriver indicated, unscrew each of these four fasteners.
The LCD screen can be easily taken off once these screws are removed.
