Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide is a step by step process to remove the top cover of the phone. It is the preliminary step, in order to gain access into the upper section of the phone.
O que você precisa
Turn off the phone.
Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
Position the phone so that the back side is in view.
Wedge the iPod opening tool between the top cover and the phone.
Gently lift the top cover away from the phone using the iPod opening tool.
This unlatches each hook that connects the top cover to the phone.
Place the top cover aside once the top cover is completely disconnected from the phone.
Uma outra pessoa concluiu este guia.
