Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Press down on the release latch on the bottom of the cover.
Once the latch is released, lift the cover from the phone.
Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
Insert a flat screwdriver between the black body and plastic layer.
Pry the layers apart. The LCD and plastic layer will lift out as one piece.
With the screws removed, the logic board can then be lifted out of the body by hand.
The orange piece is the vibrator.
It is not fastened by any means.
Remove with tweezers.
