Ir para o conteúdo principal
Disassembling Nokia 3560 Vibrator
O que você precisa
  1. Disassembling Nokia 3560 Vibrator, Back Cover: passo 1, imagem 1 %32 Disassembling Nokia 3560 Vibrator, Back Cover: passo 1, imagem 2 %32
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Keypad: passo 2, imagem 1 %32
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Vibrator: passo 3, imagem 1 %32 Disassembling Nokia 3560 Vibrator: passo 3, imagem 2 %32
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 LCD Display: passo 4, imagem 1 %32
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Vibrator: passo 5, imagem 1 %32
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Vibrator: passo 6, imagem 1 %32 Disassembling Nokia 3560 Vibrator: passo 6, imagem 2 %32
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Vibrator: passo 7, imagem 1 %32
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Logic Board: passo 8, imagem 1 %32
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: passo 9, imagem 1 %32 Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: passo 9, imagem 2 %32
    • The orange piece is the vibrator.
    • It is not fastened by any means.
    • Remove with tweezers.
Conclusão
Sam Ryan
Membro desde: 04/18/10
1 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 30-39, Garner Spring 2010 Membro de Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 1,267
