Ir para o conteúdo principal
Disassembling Nokia 2366i Motherboard
O que você precisa
  1. Disassembling Nokia 2366i Motherboard, Battery: passo 1, imagem 1 %32 Disassembling Nokia 2366i Motherboard, Battery: passo 1, imagem 2 %32
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Motherboard: passo 2, imagem 1 %32
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Motherboard: passo 3, imagem 1 %32 Disassembling Nokia 2366i Motherboard: passo 3, imagem 2 %32 Disassembling Nokia 2366i Motherboard: passo 3, imagem 3 %32
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Motherboard, Rear Case: passo 4, imagem 1 %32 Disassembling Nokia 2366i Motherboard, Rear Case: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Motherboard: passo 5, imagem 1 %32 Disassembling Nokia 2366i Motherboard: passo 5, imagem 2 %32
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Motherboard: passo 6, imagem 1 %32 Disassembling Nokia 2366i Motherboard: passo 6, imagem 2 %32
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Motherboard: passo 7, imagem 1 %32
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
  8. Disassembling Nokia 2366i Motherboard, Motherboard: passo 8, imagem 1 %32 Disassembling Nokia 2366i Motherboard, Motherboard: passo 8, imagem 2 %32
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
  9. Disassembling Nokia 2366i Motherboard: passo 9, imagem 1 %32 Disassembling Nokia 2366i Motherboard: passo 9, imagem 2 %32
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
Conclusão
Jonathan Newman
Membro desde: 01/21/11
486 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-14, Amido Winter 2011 Membro de Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 13
Duração total: 1,507
