Ir para o conteúdo principal
Disassembling Nokia 2366i Front Display
O que você precisa
  1. Disassembling Nokia 2366i Front Display, Battery: passo 1, imagem 1 %32 Disassembling Nokia 2366i Front Display, Battery: passo 1, imagem 2 %32
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Display: passo 2, imagem 1 %32
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Display: passo 3, imagem 1 %32 Disassembling Nokia 2366i Front Display: passo 3, imagem 2 %32 Disassembling Nokia 2366i Front Display: passo 3, imagem 3 %32
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Display, Front Cover: passo 4, imagem 1 %32
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Display: passo 5, imagem 1 %32 Disassembling Nokia 2366i Front Display: passo 5, imagem 2 %32
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Display: passo 6, imagem 1 %32 Disassembling Nokia 2366i Front Display: passo 6, imagem 2 %32
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
  7. Disassembling Nokia 2366i Front Display, Main Display: passo 7, imagem 1 %32 Disassembling Nokia 2366i Front Display, Main Display: passo 7, imagem 2 %32
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
  8. Disassembling Nokia 2366i Front Display: passo 8, imagem 1 %32 Disassembling Nokia 2366i Front Display: passo 8, imagem 2 %32
    • Using the spudger, disconnect the green display cable.
  9. Disassembling Nokia 2366i Front Display: passo 9, imagem 1 %32 Disassembling Nokia 2366i Front Display: passo 9, imagem 2 %32 Disassembling Nokia 2366i Front Display: passo 9, imagem 3 %32
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
  10. Disassembling Nokia 2366i Front Display, Front Display: passo 10, imagem 1 %32 Disassembling Nokia 2366i Front Display, Front Display: passo 10, imagem 2 %32 Disassembling Nokia 2366i Front Display, Front Display: passo 10, imagem 3 %32
    • Fold the metal casing back over.
    • Disconnect the orange front display data cable with the spudger.
    • Hold the phone so that the antenna is facing towards you.
    • Lift up and flip over the metal casing.
  11. Disassembling Nokia 2366i Front Display: passo 11, imagem 1 %32
    • Using your fingers, remove the front display.
Conclusão
Michael Machado
Membro desde: 01/21/11
334 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-14, Amido Winter 2011 Membro de Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 936
