Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Loosen the two screws on the battery panel. Then lift the panel up to remove it.
L Button.
Top of the battery pack.
To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
Remove 4 Phillips screws from the board.
Lift the main board from the bottom end and flip it over to reveal the last connector.
Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
The motherboard should now be free from the rest of the device.
A/B/X/Y button assembly
Select/Start button assembly
D-pad
Power button
Remove the plastic buttons and keep them in a safe place.
Flip the case open, and push the lower screen assembly out of the frame.
