Ir para o conteúdo principal
Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc.
O que você precisa
Vídeo de Apresentação
  1. Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: passo 1, imagem 1 %32 Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: passo 1, imagem 2 %32 Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: passo 1, imagem 3 %32
    • Opening the case
Conclusão
To reassemble your device, follow the complete video
46 outras pessoas executaram este guia.
LE55ONS
Membro desde: 05/30/12
10.977 Reputação
Autoria de 6 guias
7 comentários
fantastic video guide! thanks
Carlo - Responder
Brilliant, best that I have found.
andy brown - Responder
Thank you for this excellent video guide !
Matthieu Imbert - Responder
Thanks for the excellent guide. Your video has perfect quality, its easy to follow. With the help of your guide I was able to change the damaged screen in about 20 min.
Michael Pirker - Responder
Excellent guide. I managed to change a broken screen in a couple of hours. Well, it actually took a little longer... the digitizer was broken but the LCD looked ok so I just bought the digitizer (around $14 on ebay) and then separated the LCD from the broken digitizer. It really hard. I ended up with a broken LCD. So I bought the LCD+Digitizer ($46) and that was easy. Its working fine now.
Pedro - Responder
You sir, are awesome. Only thing I would say is that for me it was a Phillips #000 that worked. #00 was too big.
Michael Garramone - Responder
Amazing video, thank you!!!
Ivan Zipfer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 34,641
