Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Peças
Nenhum componente especificado.
  1. Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
    • Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
    • Remove the #00 1.2 cm Phillips screw located to the right of the white casing.
  2. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  3. An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already. Wiggle the front cover out from under the white piece and lift up from the gun. Pulling the cover off is tricky due to its inner fitting.
    • An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already.
    • Wiggle the front cover out from under the white piece and lift up from the gun.
    • Pulling the cover off is tricky due to its inner fitting.
    • Be sure to replace the orange block, spring, and clip before this step in reassembly.
  4. The spring, cap, and rotating lever will likely fall out as you remove the inner mechanism.
    • The spring, cap, and rotating lever will likely fall out as you remove the inner mechanism.
    • Disconnect the inner mechanism from the outer cover by lifting the inner mechanism towards you.
    • Be sure to replace the spring, cap, and rotating lever before this step in reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Cara Pew
Membro desde: 29/09/2014
899 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 13-6, Forte Fall 2014 Membro de Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Membros
7 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 37
