Ir para o conteúdo principal
Disassembling Motorola i90c Logic Board
O que você precisa
  1. Disassembling Motorola i90c Logic Board, Battery: passo 1, imagem 1 %32 Disassembling Motorola i90c Logic Board, Battery: passo 1, imagem 2 %32 Disassembling Motorola i90c Logic Board, Battery: passo 1, imagem 3 %32
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Logic Board: passo 2, imagem 1 %32 Disassembling Motorola i90c Logic Board: passo 2, imagem 2 %32 Disassembling Motorola i90c Logic Board: passo 2, imagem 3 %32
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Logic Board, Antenna: passo 3, imagem 1 %32 Disassembling Motorola i90c Logic Board, Antenna: passo 3, imagem 2 %32
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Logic Board, Midframe: passo 4, imagem 1 %32 Disassembling Motorola i90c Logic Board, Midframe: passo 4, imagem 2 %32 Disassembling Motorola i90c Logic Board, Midframe: passo 4, imagem 3 %32
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
  5. Disassembling Motorola i90c Logic Board: passo 5, imagem 1 %32 Disassembling Motorola i90c Logic Board: passo 5, imagem 2 %32
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Logic Board: passo 6, imagem 1 %32 Disassembling Motorola i90c Logic Board: passo 6, imagem 2 %32 Disassembling Motorola i90c Logic Board: passo 6, imagem 3 %32
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
  7. Disassembling Motorola i90c Logic Board, Logic Board: passo 7, imagem 1 %32 Disassembling Motorola i90c Logic Board, Logic Board: passo 7, imagem 2 %32
    • Lift the first logic board off of the rest of the device.
  8. Disassembling Motorola i90c Logic Board: passo 8, imagem 1 %32
    • Gently lift the second logic board from the rest of the device.
    • DO NOT force the board straight off as it could damage the ribbon cable!
  9. Disassembling Motorola i90c Logic Board: passo 9, imagem 1 %32 Disassembling Motorola i90c Logic Board: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, carefully pull off the connector shown.
Conclusão
Equipe
Cal Poly, Team 29-61, Johann Spring 2010 Membro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 86
Ao todo: 1,238
