Ir para o conteúdo principal
Disassembling Motorola i90c Internal Backplate
O que você precisa
  1. Disassembling Motorola i90c Internal Backplate, Battery: passo 1, imagem 1 %32 Disassembling Motorola i90c Internal Backplate, Battery: passo 1, imagem 2 %32 Disassembling Motorola i90c Internal Backplate, Battery: passo 1, imagem 3 %32
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Internal Backplate: passo 2, imagem 1 %32 Disassembling Motorola i90c Internal Backplate: passo 2, imagem 2 %32 Disassembling Motorola i90c Internal Backplate: passo 2, imagem 3 %32
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Internal Backplate, Antenna: passo 3, imagem 1 %32 Disassembling Motorola i90c Internal Backplate, Antenna: passo 3, imagem 2 %32
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: passo 4, imagem 1 %32 Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: passo 4, imagem 2 %32 Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: passo 4, imagem 3 %32
    • Unscrew the 3 screws shown.
    • Lift up the right part of the Nextel logo and unscrew the screw underneath.
  5. Disassembling Motorola i90c Internal Backplate: passo 5, imagem 1 %32 Disassembling Motorola i90c Internal Backplate: passo 5, imagem 2 %32
    • DO NOT force the cover off as it could damage the ribbon cable!
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Internal Backplate: passo 6, imagem 1 %32 Disassembling Motorola i90c Internal Backplate: passo 6, imagem 2 %32 Disassembling Motorola i90c Internal Backplate: passo 6, imagem 3 %32
    • Carefully pry off the connection between the headphone jack and logic board.
Conclusão
Equipe
Cal Poly, Team 29-61, Johann Spring 2010 Membro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,327
