Ir para o conteúdo principal
Disassembling Motorola i850 Keypad
O que você precisa
  1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: passo 1, imagem 1 %32
    • Use your thumb to slide the back cover locker away from the antenna.
    Pergunte ao FixBot
  2. Disassembling Motorola i850 Keypad: passo 2, imagem 1 %32 Disassembling Motorola i850 Keypad: passo 2, imagem 2 %32
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
    Pergunte ao FixBot
  3. Disassembling Motorola i850 Keypad, Battery: passo 3, imagem 1 %32
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
    Pergunte ao FixBot
  4. Disassembling Motorola i850 Keypad: passo 4, imagem 1 %32 Disassembling Motorola i850 Keypad: passo 4, imagem 2 %32
    • Lift the battery out of the phone while pushing it towards the antenna.
    Pergunte ao FixBot
  5. Disassembling Motorola i850 Keypad, Keypad: passo 5, imagem 1 %32
    • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
    Pergunte ao FixBot
  6. Disassembling Motorola i850 Keypad: passo 6, imagem 1 %32 Disassembling Motorola i850 Keypad: passo 6, imagem 2 %32 Disassembling Motorola i850 Keypad: passo 6, imagem 3 %32
    • Grip the device firmly with both hands and carefully open the device.
    • Warning: Be incredibly careful removing the back panel as you may tear the flex cable connecting the loudspeaker and side buttons.
    Pergunte ao FixBot
  7. Disassembling Motorola i850 Keypad: passo 7, imagem 1 %32 Disassembling Motorola i850 Keypad: passo 7, imagem 2 %32
    • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
    Pergunte ao FixBot
  8. Disassembling Motorola i850 Keypad: passo 8, imagem 1 %32 Disassembling Motorola i850 Keypad: passo 8, imagem 2 %32
    • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
    Pergunte ao FixBot
  9. Disassembling Motorola i850 Keypad: passo 9, imagem 1 %32 Disassembling Motorola i850 Keypad: passo 9, imagem 2 %32 Disassembling Motorola i850 Keypad: passo 9, imagem 3 %32
    • Place the back of the device on your hand and flip it over with the other hand.
    • Carefully lift the device to remove interior hardware.
    • The structure of the keypad should easily be loose from flipping the device.
    Pergunte ao FixBot
  10. Disassembling Motorola i850 Keypad: passo 10, imagem 1 %32 Disassembling Motorola i850 Keypad: passo 10, imagem 2 %32 Disassembling Motorola i850 Keypad: passo 10, imagem 3 %32
    • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
    • WARNING: The plastic keypad is sensitive and can be easily damaged.
    Pergunte ao FixBot
Conclusão
Tony Chen
Membro desde: 04/08/10
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 34-56, Forte Spring 2010 Membro de Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 39
Ao todo: 1,875
