Ir para o conteúdo principal
Motorola V180 Connector Ribbon Replacement
O que você precisa
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: passo 1, imagem 1 %32
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: passo 2, imagem 1 %32
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: passo 3, imagem 1 %32
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: passo 5, imagem 1 %32
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: passo 6, imagem 1 %32
    • Use a soldering iron to detach the connector ribbon from the phone.
Conclusão
Tyler Knisley
Membro desde: 05/07/10
1 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 6-16, Maness Spring 2010 Membro de Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 17
Duração total: 2,629
