Ir para o conteúdo principal
Disassembling Midland X-tra Talk Radio LXT118 Circuit Board
O que você precisa
  1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: passo 1, imagem 1 %32 Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: passo 1, imagem 2 %32
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: passo 2, imagem 1 %32
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Case: passo 3, imagem 1 %32
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: passo 4, imagem 1 %32
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Midland X-tra Talk Radio LXT118: passo 5, imagem 1 %32
    • Remove the old or broken circuit board from the front case by carefully separating it from the back.
    • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
Conclusão
To reassemble your device, follow these instructions in reverse order, from step 6 to 1.
Equipe
Cal Poly, Team 19-43, Regan Winter 2013 Membro de Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 890
