Ir para o conteúdo principal
Disassembling Macintosh IIsi System Fan
  1. Disassembling Macintosh IIsi System Fan, System Fan: passo 1, imagem 1 %32
    • The fan recieves power from two contacts on the logic board and has no connector.
  2. Disassembling Macintosh IIsi System Fan: passo 2, imagem 1 %32 Disassembling Macintosh IIsi System Fan: passo 2, imagem 2 %32 Disassembling Macintosh IIsi System Fan: passo 2, imagem 3 %32
    • In all of the years that I have worked on this machine, I have found no good way to remove the fan.
    • The best way to start, is to push in here on the side of the fan.
    • Being careful not to exert too much force, try to push in, and wiggle the fan outward as such. (2nd Photo)
    • You can now lift the fan all the way out, and remove it.
    • The Fan Power Contacts on the Logic Board:
Conclusão
Chris Green
Membro desde: 10/11/09
38.339 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
333 Membros
Autoria de 1.478 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 69
Ao todo: 2,150
