Ir para o conteúdo principal
Disassembling Macintosh IIsi Floppy Drive
O que você precisa
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: passo 1, imagem 1 %32 Disassembling Macintosh IIsi Floppy Drive, Top Case: passo 1, imagem 2 %32
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: passo 2, imagem 1 %32 Disassembling Macintosh IIsi Floppy Drive: passo 2, imagem 2 %32 Disassembling Macintosh IIsi Floppy Drive: passo 2, imagem 3 %32
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: passo 3, imagem 1 %32 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: passo 3, imagem 2 %32 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: passo 3, imagem 3 %32
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: passo 4, imagem 1 %32 Disassembling Macintosh IIsi Floppy Drive: passo 4, imagem 2 %32 Disassembling Macintosh IIsi Floppy Drive: passo 4, imagem 3 %32
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
Conclusão
Chris Green
Membro desde: 10/11/09
37.014 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
Um comentário
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 2,760
