Introdução
I have described how to open and fully disassemble an laptop Toshiba Satellite P885 (more exact, P855-339). The info is for any Toshiba Satellite P855 or P850.
also how to repair the hinge (broken, I have dropped the laptop on the floor).
O que você precisa
1. remove the plastic/rubber caps
2. unscrew the 12 screws.
unplug the laptop from power source & remove the batery
unscrew the 3 tiny screws behind the battery
keep the lid closed till later on
1. WIFI card - Easy to change / replace There are two cables attached to it. Remove them, then unscrew the screw that holds the card in place and lift gently up - DONE.
2. HDD / SSD. All you have to do is grab and pull the ribbon (as in photo). There are a few extra steps to change it.
1. Insert gently the cutte (or other sharp tool) and press towards the screen & flip up slowly.
To remove it completely unplug the two connectors.
1.ECO Button
2. Sound
3. Power button
4. Mouse pad
To change / remove the speakers remove the screws.
To change / remove the Eco/3D button or power button, yo have to remove first the speakers.
do not forget about the grey cable attached on the bottom side.
When reattaching the cable, put some thermal paste on the contact (gray cable)
insert the plastic dowel pin from bottom-up and level it inside at the same height with other screw holes
Cut the excess plastic from the dowel pin
Put some super-glue to fix it in place
I have glued some foam near the speakers in order to protect the aerea
Glue inside the plastic dowel pin
Use thermal paste to fix the gray cable (i have used silver paste)
11 outras pessoas executaram este guia.
2 comentários
I have a slipped HDMI port. At which step would I be able to access that?
My Toshibe C55T-B5349, I want to replace the "lid assembly" which includes the screen and digitizer. Can you give the steps? Thanks
