Ir para o conteúdo principal
Disassembling LG Vortex
O que você precisa
  1. Disassembling LG Vortex, Power down the Phone: passo 1, imagem 1 %32
    • Power the phone off
    • The power button is located on top of the phone
  2. Disassembling LG Vortex, Remove the Back Cover: passo 2, imagem 1 %32 Disassembling LG Vortex, Remove the Back Cover: passo 2, imagem 2 %32 Disassembling LG Vortex, Remove the Back Cover: passo 2, imagem 3 %32
    • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
  3. Disassembling LG Vortex: passo 3, imagem 1 %32
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Put the battery aside.
  4. Disassembling LG Vortex, Unscrew the Back Frame: passo 4, imagem 1 %32 Disassembling LG Vortex, Unscrew the Back Frame: passo 4, imagem 2 %32
    • All screws are the same size screwdriver head #00
    • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in a container to ensure they aren't lost.
    Can you tell me who I or how to get the part that I need?
    Roger Evans - Responder
    Hey it's the guy who has the V22 Vortex.That needs the chargring housing. I asked if anyone could possibly steer me in the right direction,as to where and how to get the part.But I know Just thought you AhFuck you.
  5. Disassembling LG Vortex, Remove the Back Frame: passo 5, imagem 1 %32 Disassembling LG Vortex, Remove the Back Frame: passo 5, imagem 2 %32 Disassembling LG Vortex, Remove the Back Frame: passo 5, imagem 3 %32
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
    ModelV22 Vortex. I need the charging port hole assembly.
    Ok I have aV22 Vortex.Or should I say.I need the charging plug in assembly.C charger port.I'm sure I didn't say that right.But if needed I will send a picture of it.
Conclusão
Jen
Membro desde: 02/13/14
22 Reputação
Autoria de 3 guias
Equipe
Ohio State, Team 1-3, Buehl Spring 2014 Membro de Ohio State, Team 1-3, Buehl Spring 2014
OSU-BUEHL-S14S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 102
Duração total: 4,023
