Ir para o conteúdo principal
Disassembling LG VX8550 Front Case
O que você precisa
  1. Disassembling LG VX8550 Front Case, Battery: passo 1, imagem 1 %32
    • Slide the battery release up.
    Pergunte ao FixBot
  2. Disassembling LG VX8550 Front Case: passo 2, imagem 1 %32
    • Remove the battery by lifting away from the case.
    Pergunte ao FixBot
  3. Disassembling LG VX8550 Front Case, Case: passo 3, imagem 1 %32
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
    Pergunte ao FixBot
  4. Disassembling LG VX8550 Front Case: passo 4, imagem 1 %32
    • Remove the 4 cover screws with a Philips #00 screwdriver.
    Pergunte ao FixBot
  5. Disassembling LG VX8550 Front Case: passo 5, imagem 1 %32
    • Use the iPod opening tool to pry off the back casing.
    Pergunte ao FixBot
  6. Disassembling LG VX8550 Front Case: passo 6, imagem 1 %32
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
    Pergunte ao FixBot
  7. Disassembling LG VX8550 Front Case: passo 7, imagem 1 %32
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
    Pergunte ao FixBot
  8. Disassembling LG VX8550 Front Case, Motherboard: passo 8, imagem 1 %32
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
    Pergunte ao FixBot
  9. Disassembling LG VX8550 Front Case: passo 9, imagem 1 %32
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
    Pergunte ao FixBot
  10. Disassembling LG VX8550 Front Case: passo 10, imagem 1 %32
    • Remove the motherboard from the front casing by lifting straight up.
    Pergunte ao FixBot
  11. Disassembling LG VX8550 Front Case, Keypad Housing: passo 11, imagem 1 %32
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
    Pergunte ao FixBot
  12. Disassembling LG VX8550 Front Case: passo 12, imagem 1 %32
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
    Pergunte ao FixBot
  13. Disassembling LG VX8550 Front Case: passo 13, imagem 1 %32
    • Lift the keypad housing away from the slider.
    Pergunte ao FixBot
  14. Disassembling LG VX8550 Front Case, Front Case: passo 14, imagem 1 %32
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
    Pergunte ao FixBot
  15. Disassembling LG VX8550 Front Case: passo 15, imagem 1 %32
    • Remove the 6 screws with a Phillips #00 Screwdriver.
    Pergunte ao FixBot
  16. Disassembling LG VX8550 Front Case: passo 16, imagem 1 %32
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
    Pergunte ao FixBot
  17. Disassembling LG VX8550 Front Case: passo 17, imagem 1 %32
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
    Pergunte ao FixBot
  18. Disassembling LG VX8550 Front Case: passo 18, imagem 1 %32
    • Slide ribbon cable through the slider mechanism.
    Pergunte ao FixBot
  19. Disassembling LG VX8550 Front Case: passo 19, imagem 1 %32
    • Separate the two halves.
    Pergunte ao FixBot
Conclusão
Nathan Jones
Membro desde: 04/10/10
89 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 34-55, Forte Spring 2010 Membro de Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 65
Ao todo: 2,341
