Ir para o conteúdo principal
Disassembling LG 440G Rear casing
O que você precisa
  1. Disassembling LG 440G Rear casing, Turn off phone.: passo 1, imagem 1 %32
    • Turn the device off.
    • To do so, press and hold the red button.
  2. Disassembling LG 440G Rear casing, Flip phone.: passo 2, imagem 1 %32
    • Flip the phone over.
  3. Disassembling LG 440G Rear casing, Rear cover removal.: passo 3, imagem 1 %32
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. Disassembling LG 440G Rear casing, Removal of battery.: passo 4, imagem 1 %32
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. Disassembling LG 440G Rear casing, Unscrew six screws along edges of casing: passo 5, imagem 1 %32
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. Disassembling LG 440G Rear casing, Lift casing cover: passo 6, imagem 1 %32 Disassembling LG 440G Rear casing, Lift casing cover: passo 6, imagem 2 %32
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
Conclusão
Emily Class
Membro desde: 02/17/15
107 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-1, Buehl Winter 2015 Membro de Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
Membros da 4
Autoria de 8 guias
Um comentário
this would be most probably, the same guide to tear down the LG B470
douglas flores - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,663
