Introdução
This guide shows how to disassemble the rear casing on a LG 440G to access the electronics.
This disassembly requires 2 tools, a Phillips #00 screw driver and an opening tool.
O que você precisa
Locate the small rounded recess to get access to the battery
Gently, lift the battery
Use a Phillips #00 screw driver to remove six screws.
Run the plastic opening tool along the edge of the phone to release the casing cover.
Lift the casing cover.
Um comentário
this would be most probably, the same guide to tear down the LG B470
