Ir para o conteúdo principal
Disassembling Kodak Advantix F350 Back Cover
O que você precisa
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: passo 1, imagem 1 %32
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: passo 2, imagem 1 %32 Disassembling Kodak Advantix F350 Back Cover: passo 2, imagem 2 %32
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: passo 3, imagem 1 %32 Disassembling Kodak Advantix F350 Back Cover: passo 3, imagem 2 %32 Disassembling Kodak Advantix F350 Back Cover: passo 3, imagem 3 %32
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: passo 4, imagem 1 %32 Disassembling Kodak Advantix F350 Back Cover: passo 4, imagem 2 %32
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: passo 5, imagem 1 %32 Disassembling Kodak Advantix F350 Back Cover: passo 5, imagem 2 %32
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: passo 6, imagem 1 %32 Disassembling Kodak Advantix F350 Back Cover: passo 6, imagem 2 %32 Disassembling Kodak Advantix F350 Back Cover: passo 6, imagem 3 %32
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Conclusão
David Cottrell
Membro desde: 10/04/11
88 Reputação
Autoria de 5 guias
Equipe
UW Stout, Team 1-2, Zhou Fall 2011 Membro de UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,079
