Introdução
These instructions will demonstrate how to remove the logic board from the KDDI Kyocera A5521K.
O que você precisa
Turn the phone over to expose the battery cover.
Apply pressure to the back of the battery cover to slide it down.
The battery cover is now separate from the phone.
Rotate the phone approximately 45 degrees to the right.
Gently pry up the SD card slot with a spudger.
Lift up on the first connection shown using a pair of pliers.
Disconnect the first connection between the logic board and the wire using the pair of pliers.
