Ir para o conteúdo principal
Disassembling KDDI Kyocera A5521K Faceplate
O que você precisa
  1. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: passo 1, imagem 1 %32 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: passo 1, imagem 2 %32 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: passo 1, imagem 3 %32
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Faceplate: passo 2, imagem 1 %32 Disassembling KDDI Kyocera A5521K Faceplate: passo 2, imagem 2 %32 Disassembling KDDI Kyocera A5521K Faceplate: passo 2, imagem 3 %32
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, imagem 1 %32 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, imagem 2 %32 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, imagem 3 %32
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. Disassembling KDDI Kyocera A5521K Faceplate: passo 4, imagem 1 %32
    • Remove the screws using a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Faceplate: passo 5, imagem 1 %32 Disassembling KDDI Kyocera A5521K Faceplate: passo 5, imagem 2 %32 Disassembling KDDI Kyocera A5521K Faceplate: passo 5, imagem 3 %32
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. Disassembling KDDI Kyocera A5521K Faceplate: passo 6, imagem 1 %32
    • Use the Y0 screwdriver to remove the screws.
  7. Disassembling KDDI Kyocera A5521K Faceplate: passo 7, imagem 1 %32 Disassembling KDDI Kyocera A5521K Faceplate: passo 7, imagem 2 %32
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. Disassembling KDDI Kyocera A5521K Faceplate: passo 8, imagem 1 %32 Disassembling KDDI Kyocera A5521K Faceplate: passo 8, imagem 2 %32 Disassembling KDDI Kyocera A5521K Faceplate: passo 8, imagem 3 %32
    • Separate the faceplate from the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Dominic Grisafe
Membro desde: 04/15/10
157 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 28-25, Regan Spring 2010 Membro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,698
