Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The lower bracket needs to be removed to get to some components of the laptop.
O que você precisa
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
The metal bracket will now be free to move, grasp it and remove it from the device.
Remove the small rubber piece that is covering the T42's microphone,
Uma outra pessoa concluiu este guia.
