Ir para o conteúdo principal
  1. Este passo não foi traduzido. Ajude a traduzi-lo
    Flip the ThinkPad over so that it is upside down. Slide the highlighted tab to the left.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the highlighted screw with a Phillips #1 screwdriver. Pull the hard drive out. Pull the hard drive out.
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
  3. Este passo não foi traduzido. Ajude a traduzi-lo
    Make sure the laptop is upside down and oriented in the direction shown.
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  4. Este passo não foi traduzido. Ajude a traduzi-lo
    Rotate the ThinkPad so that the hard drive bay is facing you.
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  5. Este passo não foi traduzido. Ajude a traduzi-lo
    Flip the ThinkPad over and open the LCD panel. Pry apart the keyboard with a plastic opening tool or with your fingers.
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  6. Este passo não foi traduzido. Ajude a traduzi-lo
    Be careful not to pull out the keyboard carelessly; there is a connector underneath it! Lift the front end of the keyboard as shown. Using your fingers, remove the black film cover.
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  7. Este passo não foi traduzido. Ajude a traduzi-lo
    Locate the connector attached to the motherboard. Disconnect the ribbon cable by removing the connector. Disconnect the ribbon cable by removing the connector.
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  8. Este passo não foi traduzido. Ajude a traduzi-lo
    Lift and remove the keyboard. Remove the two 5.6mm screws.
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  9. Este passo não foi traduzido. Ajude a traduzi-lo
    You will need to use a little force. Be wary of the tabs. Pry off the upper case with your hands. Pry off the upper case with your hands.
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Alan
Membro desde: 07/10/2010
380 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team 4-44, Amido Fall 2010 Membro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membros
26 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,912
