Ir para o conteúdo principal
Disassembling IBM ThinkPad A30 Modem and Ethernet Cards
O que você precisa
  1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: passo 1, imagem 1 %32 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: passo 1, imagem 2 %32
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: passo 2, imagem 1 %32 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: passo 2, imagem 2 %32
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  3. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 3, imagem 1 %32
    • Remove the four 9.1mm screws attached to the ethernet and modem cards.
  4. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 4, imagem 1 %32 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 4, imagem 2 %32 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 4, imagem 3 %32
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    • Remove the cables that attach the modem and ethernet cards.
Conclusão
Alan
Membro desde: 10/07/10
380 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 4-44, Amido Fall 2010 Membro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membros
Autoria de 26 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 2,028
