Ir para o conteúdo principal
Disassembling Home Stereo and Theater Philips MCD288
O que você precisa
  1. Disassembling Home Stereo and Theater Philips MCD288, Undo screws: passo 1, imagem 1 %32
    • remove the 4 screws on the bottem of the main set
  2. Disassembling Home Stereo and Theater Philips MCD288, Expose main latches: passo 2, imagem 1 %32
    • Lift the aluminium pane at both sides with a spudger.
  3. Disassembling Home Stereo and Theater Philips MCD288, Start with the bottom edges: passo 3, imagem 1 %32
    • To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
    • hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
  4. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: passo 4, imagem 1 %32 Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: passo 4, imagem 2 %32
    • To detach the sides, pull a main latch towards you and keep on lifting the top part further.
    • repeat for three latches on each side.
  5. Disassembling Home Stereo and Theater Philips MCD288, The inside: passo 5, imagem 1 %32 Disassembling Home Stereo and Theater Philips MCD288, The inside: passo 5, imagem 2 %32
    • These pictures show the latches on each edge and on the top of the set.
Conclusão
Philipp
Membro desde: 03/16/15
71 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 20
Últimos 30 dias: 81
Duração total: 7,478
