Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip your device over so the bottom panel is facing up.
The battery is held in by a latch in the front and tabs in the back.
Slide the lock switch left, towards the center of the computer.
Lift up the battery, rotating it up and away from you, then pull it out.
Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
Gently pull up on the plastic tab attached to the hard drive.
Pull the hard drive up and to the right to remove it completely from the laptop.
