Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Peças
Nenhum componente especificado.
  1. Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. The battery is held in by a latch in the front and tabs in the back.
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  4. Unscrew one Phillips #1 screw from the back panel.
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  5. Slide the back panel down and pull it up. Slide the back panel down and pull it up.
    • Slide the back panel down and pull it up.
  6. Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive. Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  7. Gently pull up on the plastic tab attached to the hard drive. Pull the hard drive up and to the right to remove it completely from the laptop.
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
Conclusão
John Sutton
Membro desde: 24/04/2014
1.485 Reputação
8 Guias de autoria
Equipe
Cal Poly, Team 11-51, Amido Spring 2014 Membro de Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Membros
12 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 60
