Ir para o conteúdo principal
Disassembling HP Pavilion g7-2275dx Front Panel
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Disassembling HP Pavilion g7-2275dx Front Panel, Front Panel: passo 1, imagem 1 %32
    • Unscrew the four 7 mm Phillips #1 screws on the board.
  2. Disassembling HP Pavilion g7-2275dx Front Panel: passo 2, imagem 1 %32 Disassembling HP Pavilion g7-2275dx Front Panel: passo 2, imagem 2 %32 Disassembling HP Pavilion g7-2275dx Front Panel: passo 2, imagem 3 %32
    • Use a plastic opening tool to lift the white clip up, towards the screen.
    • Pull the white cable with blue head, away from the clip.
  3. Disassembling HP Pavilion g7-2275dx Front Panel: passo 3, imagem 1 %32 Disassembling HP Pavilion g7-2275dx Front Panel: passo 3, imagem 2 %32
    • With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
    • If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • You should hear clips releasing from the board.
  4. Disassembling HP Pavilion g7-2275dx Front Panel: passo 4, imagem 1 %32
    • Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
  5. Disassembling HP Pavilion g7-2275dx Front Panel: passo 5, imagem 1 %32 Disassembling HP Pavilion g7-2275dx Front Panel: passo 5, imagem 2 %32
    • Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
    • Set aside the top panel until your are ready to reassemble your laptop.
Conclusão
Erik Miller
Membro desde: 04/22/14
2.123 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 11-51, Amido Spring 2014 Membro de Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
Membros da 4
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 48
