Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
In order to gain access to most of the internal components the top (or lid) of the printer must be removed. This guide is intended as a prerequisite for other installations.
Peças
Nenhum componente especificado.
  1. Open the front access panel by placing your finger in the front slot and pulling gently.
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
    • Remove the four 9mm T10 Torx screws on the top.
  4. Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
Conclusão
21 outras pessoas concluíram este guia.
Tim
Membro desde: 15/01/2013
184 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 18-35, Regan Winter 2013 Membro de Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 Membros
8 Guias de autoria
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 53
Duração total: 8,622
