Ir para o conteúdo principal
HP Deskjet F4480 Top Lid Replacement
O que você precisa
  1. HP Deskjet F4480 Top Lid Replacement, Open front access panel: passo 1, imagem 1 %32
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Top Lid Replacement, Top Lid: passo 2, imagem 1 %32
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet F4480 Top Lid Replacement: passo 3, imagem 1 %32 HP Deskjet F4480 Top Lid Replacement: passo 3, imagem 2 %32 HP Deskjet F4480 Top Lid Replacement: passo 3, imagem 3 %32
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet F4480 Top Lid Replacement: passo 4, imagem 1 %32 HP Deskjet F4480 Top Lid Replacement: passo 4, imagem 2 %32
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet F4480 Top Lid Replacement: passo 5, imagem 1 %32 HP Deskjet F4480 Top Lid Replacement: passo 5, imagem 2 %32 HP Deskjet F4480 Top Lid Replacement: passo 5, imagem 3 %32
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
Conclusão
21 outras pessoas executaram este guia.
Tim
Membro desde: 01/15/13
184 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-35, Regan Winter 2013 Membro de Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
Membros da 5
Autoria de 15 guias
Um comentário
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 9,508
