Ir para o conteúdo principal
Disassembling HP Compaq dx2000MT Hard Drive
O que você precisa
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: passo 1, imagem 1 %32
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: passo 2, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 2, imagem 2 %32
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: passo 3, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 3, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 3, imagem 3 %32
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: passo 4, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 4, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 4, imagem 3 %32
    • Once again, this may take considerable force.
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: passo 5, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: passo 5, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: passo 5, imagem 3 %32
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: passo 6, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 6, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 6, imagem 3 %32
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. Disassembling HP Compaq dx2000MT Hard Drive: passo 7, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 7, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 7, imagem 3 %32
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: passo 8, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 8, imagem 2 %32
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: passo 9, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 9, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 9, imagem 3 %32
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: passo 10, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 10, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 10, imagem 3 %32
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: passo 11, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 11, imagem 2 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 11, imagem 3 %32
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: passo 12, imagem 1 %32 Disassembling HP Compaq dx2000MT Hard Drive: passo 12, imagem 2 %32
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
Conclusão
4 outras pessoas executaram este guia.
Eva Pong
Membro desde: 09/22/11
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-16, Regan Fall 2011 Membro de Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
Membros da 4
Autoria de 17 guias
2 comentários
can i upgrade it to 500gb?
connor gouws - Responder
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
Thomas Daniel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 55
Duração total: 8,437
