Ir para o conteúdo principal
Disassembling General Electric Telephone 2-9710A Handset
O que você precisa
  1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: passo 1, imagem 1 %32 Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: passo 1, imagem 2 %32
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Handset: passo 2, imagem 1 %32 Disassembling General Electric Telephone 2-9710A Handset: passo 2, imagem 2 %32 Disassembling General Electric Telephone 2-9710A Handset: passo 2, imagem 3 %32
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: passo 3, imagem 1 %32 Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: passo 3, imagem 2 %32
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Disassembling General Electric Telephone 2-9710A Handset: passo 4, imagem 1 %32
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Disassembling General Electric Telephone 2-9710A Handset: passo 5, imagem 1 %32 Disassembling General Electric Telephone 2-9710A Handset: passo 5, imagem 2 %32
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. Disassembling General Electric Telephone 2-9710A Handset: passo 6, imagem 1 %32 Disassembling General Electric Telephone 2-9710A Handset: passo 6, imagem 2 %32
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. Disassembling General Electric Telephone 2-9710A Handset: passo 7, imagem 1 %32
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. Disassembling General Electric Telephone 2-9710A Handset: passo 8, imagem 1 %32 Disassembling General Electric Telephone 2-9710A Handset: passo 8, imagem 2 %32
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. Disassembling General Electric Telephone 2-9710A Handset: passo 9, imagem 1 %32 Disassembling General Electric Telephone 2-9710A Handset: passo 9, imagem 2 %32
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. Disassembling General Electric Telephone 2-9710A Handset: passo 10, imagem 1 %32
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
Conclusão
Alles Rebel
Membro desde: 09/20/12
72 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 16-59, Forte Fall 2012 Membro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 2,694
