Ir para o conteúdo principal
Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case
O que você precisa
  1. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: passo 1, imagem 1 %32
    • Unplug the toaster from the electrical outlet.
  2. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: passo 2, imagem 1 %32 Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: passo 2, imagem 2 %32
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: passo 3, imagem 1 %32
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
Conclusão
Ron Gajdos
Membro desde: 10/16/13
307 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 Membro de UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 1,088
