Ferramentas
Peças
Nenhum componente especificado.
Flip the device to the backside, and locate the metal tab at the center of the back cover.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
3 outras pessoas concluíram este guia.
2 comentários
Hello, friend. Name’s Arthur. I have this old Garmin Etrex H GPS device (the yellow one) and it looks very similar to your Etrex Vista H, but it has no stick button. The disassembling method suited just fine here, so I thank you Sir for this tutorial. I was trying to disassembly my Garmin because I am having a problem with its display. There’s a vertical line that its not displaying, so I decided to take a look. However, there was something strange. The display contacts were not locked by a connector, but by something like a durex tape. Seemed very precarious. Have you ever disassembled this yellow Etrex H model? Any ideas on how to solve my problem?
I forgot to remove battery for years and the battery chamber got damaged. So chamber was cleaned and repaired but now I cannot on it.
