Ir para o conteúdo principal
Disassembling Garmin Nuvi 370 Into Core Components
O que você precisa
  1. Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: passo 1, imagem 1 %32 Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: passo 1, imagem 2 %32
    • Unscrew the two screws on the antenna unit using a torc-head screwdriver.
    • The Torx-Head Screws' size is T-5, which is about 1.5mm.
    • Gently pry open the antenna unit with your fingers.
    • Be careful and try not to damage the small plastic tab.
    Pergunte ao FixBot
  2. Disassembling Garmin Nuvi 370 Into Core Components: passo 2, imagem 1 %32 Disassembling Garmin Nuvi 370 Into Core Components: passo 2, imagem 2 %32 Disassembling Garmin Nuvi 370 Into Core Components: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Slide out the inner casing attached to the antenna body.
    • Remove the rotating joint connecting the antenna casing to the main device:
    • Squeeze tweezers into the shown location and compress the spring.
    • Lift out the outer casing while keeping the spring compressed.
    • watch out, as the spring loaded portion may fly out unexpectedly.
    Pergunte ao FixBot
  3. Disassembling Garmin Nuvi 370 Into Core Components: passo 3, imagem 1 %32
    • Using a torx-head screwdriver, unscrew the two revealed screws that connect the front and back of the device.
    Pergunte ao FixBot
  4. Disassembling Garmin Nuvi 370 Into Core Components: passo 4, imagem 1 %32 Disassembling Garmin Nuvi 370 Into Core Components: passo 4, imagem 2 %32 Disassembling Garmin Nuvi 370 Into Core Components: passo 4, imagem 3 %32
    • Insert the plastic opening tool into the center of the edge as shown in first picture.
    • Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture.
    Pergunte ao FixBot
  5. Disassembling Garmin Nuvi 370 Into Core Components: passo 5, imagem 1 %32 Disassembling Garmin Nuvi 370 Into Core Components: passo 5, imagem 2 %32 Disassembling Garmin Nuvi 370 Into Core Components: passo 5, imagem 3 %32
    • Detach the front display from the back panel of the device.
    Pergunte ao FixBot
  6. Disassembling Garmin Nuvi 370 Into Core Components: passo 6, imagem 1 %32 Disassembling Garmin Nuvi 370 Into Core Components: passo 6, imagem 2 %32
    • Using tweezers, gently lift the microphone from its resting position to fully separate the device into two parts.
    • Finally, remove the screw that connects the motherboard to the back casing with a 3mm head driver.
    Pergunte ao FixBot
Conclusão
Robert
Membro desde: 04/19/13
80 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-65, Johann Spring 2013 Membro de Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 77
Ao todo: 1,729
