Ir para o conteúdo principal
Disassembling Fujifilm Endeavor 100ix Outer Casing
O que você precisa
  1. Disassembling Fujifilm Endeavor 100ix Outer Casing, Outer Casing: passo 1, imagem 1 %32
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 2, imagem 1 %32
    • Locate the battery door.
  3. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 3, imagem 1 %32
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 4, imagem 1 %32
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 5, imagem 1 %32
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 6, imagem 1 %32 Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 6, imagem 2 %32
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 7, imagem 1 %32
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 8, imagem 1 %32
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 9, imagem 1 %32
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 10, imagem 1 %32
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 11, imagem 1 %32 Disassembling Fujifilm Endeavor 100ix Outer Casing: passo 11, imagem 2 %32
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
Conclusão
Eric Nicolai
Membro desde: 01/10/11
679 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-5, Forte Winter 2011 Membro de Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,356
