Ir para o conteúdo principal
Disassembling Ericsson CF 388 Sim Card
  1. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: passo 1, imagem 1 %32 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: passo 1, imagem 2 %32 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: passo 1, imagem 3 %32
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: passo 2, imagem 1 %32 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: passo 2, imagem 2 %32
    • After removing the battery, the SIM card is accessible. Locate the SIM card casing at the bottom right of the back of the front panel casing.
    • To remove the SIM card, using your index finger, carefully lift up and rotate the plastic casing.
    • Then, the SIM card easily slides out of the casing.
Conclusão
Cam Miller
Membro desde: 03/09/12
1 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 1-1, Benson Spring 2012 Membro de Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Membros
Autoria de 21 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 53
Ao todo: 1,230
