Ir para o conteúdo principal
Disassembling Dell Inspiron One 2020 Back Cover
O que você precisa
  1. Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: passo 1, imagem 1 %32 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: passo 1, imagem 2 %32 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: passo 1, imagem 3 %32
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Disassembling Dell Inspiron One 2020 Back Cover: passo 2, imagem 1 %32 Disassembling Dell Inspiron One 2020 Back Cover: passo 2, imagem 2 %32 Disassembling Dell Inspiron One 2020 Back Cover: passo 2, imagem 3 %32
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Disassembling Dell Inspiron One 2020 Back Cover: passo 3, imagem 1 %32 Disassembling Dell Inspiron One 2020 Back Cover: passo 3, imagem 2 %32 Disassembling Dell Inspiron One 2020 Back Cover: passo 3, imagem 3 %32
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
Conclusão
28 outras pessoas executaram este guia.
Tyler
Membro desde: 06/19/12
4.893 Reputação
16 Guias de autoria
Equipe
TechForce Membro de TechForce
Business
2 Membros
25 Guias de autoria
Um comentário
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 105
Duração total: 33,143
