Introdução
Before starting, please:
- make sure nothing is attached (such as AC adapter, USB, VGA, audio jack).
- remove any inserted SD card.
O que você precisa
Slide the switch on the bottom of the laptop until the battery pops out.
Once the battery pops out, you can remove it.
Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
