Introdução
Laptops commonly come with a built in webcam, and sometimes they may malfunctioning, requiring replacement. In this guide you will be guided step by step through the process of replacing the webcam.
The laptop webcam in question is the unspecified HP Webcam with an integrated microphone from the HP Compaq Mini 110.
There is no specific set of skills required for this fix, but do note that a slight learning curve may appear in the case of knowing what to pullout. Do not worry, as it is a fairly easy and simple process once you get the hang of it.
O que você precisa
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the four screws that keep the bottom of the hinges attached to the base.
After removing the cable from the back of the screen, detach the webcam assembly.
