Ir para o conteúdo principal
Compaq Mini 110 Display Assembly Replacement
O que você precisa
  1. Compaq Mini 110 Display Assembly Replacement, Battery: passo 1, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Compaq Mini 110 Display Assembly Replacement: passo 2, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 2, imagem 2 %32 Compaq Mini 110 Display Assembly Replacement: passo 2, imagem 3 %32
    • Push both tabs inward simultaneously and slide the battery out.
  3. Compaq Mini 110 Display Assembly Replacement, RAM: passo 3, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement, RAM: passo 3, imagem 2 %32
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Compaq Mini 110 Display Assembly Replacement: passo 4, imagem 1 %32
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Compaq Mini 110 Display Assembly Replacement, Keyboard: passo 5, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement, Keyboard: passo 5, imagem 2 %32
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Compaq Mini 110 Display Assembly Replacement: passo 6, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 6, imagem 2 %32
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Compaq Mini 110 Display Assembly Replacement: passo 7, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 7, imagem 2 %32
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Compaq Mini 110 Display Assembly Replacement: passo 8, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 8, imagem 2 %32
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
  9. Compaq Mini 110 Display Assembly Replacement, Hard Drive: passo 9, imagem 1 %32
    • Remove the three screws holding the panel in place.
  10. Compaq Mini 110 Display Assembly Replacement: passo 10, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 10, imagem 2 %32
    • Pull up on the tab to remove the hard drive.
  11. Compaq Mini 110 Display Assembly Replacement, Top Cover: passo 11, imagem 1 %32
    • Remove the eight screws that are from the plastic top cover.
  12. Compaq Mini 110 Display Assembly Replacement: passo 12, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 12, imagem 2 %32 Compaq Mini 110 Display Assembly Replacement: passo 12, imagem 3 %32
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
  13. Compaq Mini 110 Display Assembly Replacement: passo 13, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 13, imagem 2 %32
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
  14. Compaq Mini 110 Display Assembly Replacement, Display Assembly: passo 14, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement, Display Assembly: passo 14, imagem 2 %32 Compaq Mini 110 Display Assembly Replacement, Display Assembly: passo 14, imagem 3 %32
    • Remove the four screws that keep the bottom of the hinges attached to the base.
  15. Compaq Mini 110 Display Assembly Replacement: passo 15, imagem 1 %32 Compaq Mini 110 Display Assembly Replacement: passo 15, imagem 2 %32 Compaq Mini 110 Display Assembly Replacement: passo 15, imagem 3 %32
    • Pry off the top plastic cover of the display assembly.
    • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
    • There is adhesive tape holding the cover on.
Conclusão
5 outras pessoas executaram este guia.
alea
Membro desde: 10/06/10
1.405 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 22-2, Maness Fall 2010 Membro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
Membros da 6
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 15
Duração total: 7,376
