Ir para o conteúdo principal
Disassembling Coby Kyros MID9742 Outer Casing
O que você precisa
  1. Disassembling Coby Kyros MID9742 Outer Casing, Outer Casing: passo 1, imagem 1 %32
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Disassembling Coby Kyros MID9742 Outer Casing: passo 2, imagem 1 %32
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Disassembling Coby Kyros MID9742 Outer Casing: passo 3, imagem 1 %32
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
Conclusão
Uma outra pessoa concluiu este guia.
Ian Swett
Membro desde: 03/11/15
597 Reputação
Autoria de 5 guias
Equipe
Colorado Springs, Team 5-3, Panko Spring 2015 Membro de Colorado Springs, Team 5-3, Panko Spring 2015
UCCS-PANKO-S15S5G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 475
