Ir para o conteúdo principal
Disassembling Circo Monkey Alarm Clock Clock Face
O que você precisa
  1. Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: passo 1, imagem 1 %32 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: passo 1, imagem 2 %32 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: passo 1, imagem 3 %32
    • Grasp the plastic cover and carefully pull straight back so that the clock cover dislodges from its housing.
    • If any additional assistance is required for this step, it is recommended to use the plastic opening tool to help pry the edges of the cover simultaneously or a suction cup if you cannot grip the rim.
  2. Disassembling Circo Monkey Alarm Clock Clock Face: passo 2, imagem 1 %32
    • Using your fingers, grasp the point where the hands of the clock meet in the center and pull straight back until they dislodge from the motor.
    • Be sure that you remove all three hands as well as the pin that connects them in this one step. This component should come out as a single piece.
Conclusão
Uma outra pessoa concluiu este guia.
Devin Gooding
Membro desde: 01/20/15
110 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 19-1, Blackwell Winter 2015 Membro de USF Tampa, Team 19-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G1
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 605
